87 Honda TRX250X interchangeable Parts
Old Feb 24, 2010 | 11:55 AM
Kawasabi's Avatar
Default 87 Honda TRX250X interchangeable Parts
Hello All,
Just picked up a 87 Honda TRX250X and its missing the rear brake setup and I am having a hard time locating the parts on EBAY under TRX250X. Does anyone know what other alternatives I have? Is the rear brakes setup used on a different ATVs or maybe even one of the Honda dirt bikes?
Thank
Ryan
Old Feb 24, 2010 | 12:10 PM
budedm's Avatar
Any year 300EX will interchange.
Old Feb 24, 2010 | 01:13 PM
Kawasabi's Avatar
Thanks
Old Feb 24, 2010 | 01:31 PM
Kawasabi's Avatar
Just check a dealer OEM site an dthe part numbers are different.
Old Feb 25, 2010 | 01:19 AM
KNOWSALOT's Avatar
The Facility
No,..part numbers will not always be the same because Honda changes part numbers on an item every time a different maker is building them for Honda. Or any time they change the shade of color paint. Or any time that they change any little thing...which doesnt have to play a role in fitment. Meaning different vendors for Honda make them, but they are still the same part.
Remember, Honda and other OEMs do not make their own brake components,..other companies do it for them and that's why brake parts switch so often between brands and models.
Rear brake lines and rear brake master cylinders will have to come off of an 87-92 250X or 93-09 300EX.
As for the caliper, your options are pretty much endless.
Not just Hondas either but several Yamahas and Kawasakis use the same caliper as the 250X...you just have to have the correct bracket.
If you dont have the 250X caliper bracket you have to use a 87-92 250X or 93-09 300Ex rear caliper and be sure it has the mounting bracket on it. (And I'm not talking about the bracket that attaches to the axle assembly...that's another bracket altogether).
If you already have the 250X bracket, an ATC200X, ATC350X, or any model 400EX rear caliper will work...along with dozens of other brand ATVs. A trip to a local ATV salvage yard should turn up something you can use if you have one. If not, try ebay.
Old Sep 3, 2019 | 06:53 PM
Rob Jackson's Avatar
Default 87 250x
Hey guys just picked up a 87 250x and basically it was Frankensteined... so let's get right to my point here I'm trying to figure out what year trx300ex interchanges. I'm trying to figure out if I use the wiring harness,stator,cdi,ect will it work?
Old Sep 4, 2019 | 01:52 AM
Unless you actually need a stator, I would be looking at the later 250s for a wiring loom etc. New 250s have a surprising similarity to 1980s stuff in that respect. I don't know the X but if it has a two wires to regulator stator and AC ignition, most of it will be the same electrically as later 250s. Though the position of components may differ totally which could give a few problems.
Bigreddog
Jun 27, 2017 07:57 PM
Twisty
Oct 21, 2011 01:29 AM
Michaela521
Apr 22, 2007 05:44 AM
MALOCHALA
Jun 17, 2004 10:47 AM
BCLINEHAND
Oct 14, 2003 08:40 PM
