1991 Honda XR 250l dripping oil a lot!
Old Feb 24, 2010 | 11:58 AM
4wheelingaj's Avatar
Post 1991 Honda XR 250l dripping oil a lot!
hey everyone, i was wondering if you guys could give me some advice. I have a 1991 Honda XR 250l that is really dripping oil out of the bottom of the crankcase, can you guys help?
Old Feb 25, 2010 | 08:13 AM
KNOWSALOT's Avatar
The Facility
No one can help you until you have located the source of the leak. Could be a leaking center case gasket, cracked case, leaking oil drain bolt, bad oil drain bolt gasket, bad countershaft seal, etc,etc,etc.
Take your skidplate off and pressure wash the entire bottomend of the engine and then let it run to pin point the leak.
The biggest job would be a center case gasket leak.
A cracked case would require a good welder who is familiar with engine design.
The other causes are no big deal to fix.
Old Feb 25, 2010 | 11:54 PM
JRM's Avatar
JRM
come join us on the xr250 form on thumpertalk.com but to address your issue, yeah prob a drain plug washer or oil cooler line. find the leak and let us know.
bmxatv10
Oct 14, 2022 06:23 PM
NewGuy2481
Oct 6, 2015 05:54 AM
stcspiderman
Sep 13, 2015 05:15 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
