2001 rubicon transmision noise.
Old Feb 28, 2010 | 06:45 PM
YIYO's Avatar
Exclamation 2001 rubicon transmision noise.
Hi,! I hope some one has an answer for the problem I am having with my quad,
whe I shift in to drive, it sounds like there is a worn out gear in the transmision, the motor runs fine, but it only makes the noise in gear, it moves but it makes a grinding noise, in reverse it is less, I opened the engine complete, did not found any metal shavings or pieces of metal. the engine is back on the quad, installed a new mud cam, tested today and the noise still there, can anyone please help!!!!!!!!.
Old Feb 28, 2010 | 06:56 PM
Specta's Avatar
I wouldn't drive it and I would take it to someone who can check the oil pressure.
Old Feb 28, 2010 | 10:14 PM
JRM's Avatar
JRM
if memory serves me correct i beleve honda mechanic told the last person with this issue that it was something in the sub transmission- make sure that the engine is not above idle when you put in in gear.
Old Mar 1, 2010 | 04:31 PM
HondaMechanic's Avatar
The sub-transmission can slip if not adjusted right , but if it's making a ratcheting noise the problem is probably the hydrostatic unit ..
Old Mar 2, 2010 | 12:28 AM
YIYO's Avatar
thanks for the info, I am going to check the oil pressure, and go from there,
the sound that makes is like when you strip an axle, or a gear,the trany seems to be fine, because i ran the bike on jack stands and I shifted all gears on esp mode, it moves but as soon as I grave the rear brak an put presure it starts to make the noise, i am thinking more of a worn gear. thanks again for the info.!!!!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
