1999 Prairie 400 Carb adjustments
Old Mar 2, 2010 | 03:09 PM
Valverde's Avatar
Default 1999 Prairie 400 Carb adjustments
Can anyone enlighten me on what can or cannot be adjusted on the carb? The only adjustment that I can find is the needle on the bottom, is that it? if so, where should it be set?
Thanks for your help!
Old Mar 2, 2010 | 06:22 PM
NorminNB's Avatar
Default Carb Adjustment 400 Prairie
My manual, says, Idle speed adjustment=Engine running and warm, turn the idle screw to obtain the slowest smooth idle speed. Pilot screw adjustment=Turn the pilot screw all the way in until it seats LIGHTLY. Then back the pilot screw out 2 turns. Hope this helps. NorminN.B.
Old Mar 3, 2010 | 09:31 AM
Valverde's Avatar
I will give it a shot, Thanks!
Old Mar 5, 2010 | 02:46 PM
Valverde's Avatar
Two full turns out and a significant improvement, I am idling smooth but still some sputter on the top end under acceleration. Thanks.
Old Mar 6, 2010 | 09:16 AM
Valverde's Avatar
Just took it for a test run and still not tolerable under acceleration. Can you point me in the direction of the manual you refer to, my owners manual does not refer to any carb settings. Is there anything online?
Old Mar 6, 2010 | 10:22 AM
NorminNB's Avatar
try a quarter turn, more, open, if that doesn't help, try a quarter turn closed. Check the screen filters in the tank, u need to remove the shut off valve, to get to them. Are ur valves adjusted properly? NorminN.B.
Old Mar 7, 2010 | 09:30 AM
Valverde's Avatar
It had been sitting for a while and would not idle, but would run great on "Choke". I soaked the carb, blew it out and now it idles great but spits and sputters under acceleration. I will try adjusting again, its just very hard to get to.
Old Mar 20, 2010 | 11:38 AM
Kerbbirds's Avatar
Did you remove the jets and clean them with carb cleaner then bliow through them with compressed air? If its been sitting, drain all the old gas andstart fresh.
Old Jun 14, 2010 | 09:54 PM
MrSummit's Avatar
Default Carb jets
ditto - if it sat for some time and the jets are plugged, you should make certain the jets and all the little air passages on the carb are clean. Soak the jets in some carb soak solution.
micheleLeigh
Jul 12, 2015 02:50 AM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
