2001 Prairie 300 Leaking Gas
Old Mar 4, 2010 | 07:37 PM
bitterfitter's Avatar
Default 2001 Prairie 300 Leaking Gas
I took my 850 out today to bomb around in the snow before it's gone. Had a blast for about an hour. (Got cold!) Parked it in the garage. My wife gets home 2 hours later and says she smells gas in the garage... Natural gas or gasoline?? gasoline. Now I'm pissed, thinking I did something to my XP and caused a gas leak. Look all over it, and no gas leak. Check the snowblower, no gas leak.. gas cans, weedwacker, nothing. Look under the Kawi with a flashlight and see a drip fall. Look closer and there's what appears to be a vent line above the swingarm mount dripping gasoline about 5 drips a minute. It is too late to get into now, but I closed the fuel supply from the tank. Is there a carb vent that could leak on a quad that hasn't moved in 5 months?? I was going to rebuild the carb before the riding season anyways, so maybe I'll find out what it is then. This little ride has been about bulletproof for 9 years. Any help would be greatly appreciated.
Old Mar 4, 2010 | 09:44 PM
mxoverdrive03's Avatar
thats the over flow tube,needle an seat are not closing, the needle that is attach to the float, after sitting for awhile gas gums up the carb and wont allow it to close, pull the bowl off and clean it
Old Mar 5, 2010 | 01:52 PM
Good thing I'm going to clean and rebuild the carb soon, huh? Guess it'll be sooner rather than later. My garage still stinks of gasoline.
Old Mar 7, 2010 | 09:04 AM
try shutting off the fuel supply on the bottom of the tank that should stop the leaking
Old Mar 7, 2010 | 09:13 AM
Snow Rider's Avatar
I'm experiencing the same problem with my 2001 Lakota 300 and one of the Warrior 350s (which just had its carb rebuilt...). The leaking only happens when the engine is off, so I just shut the fuel valve off when it's not running. I don't mind working around it this way, but is it harmful while the engine is running?
Old Mar 7, 2010 | 10:55 AM
I had shut off the fuel supply the day I found it leaking and it did stop. It's a moot point now as I pulled the carb yesterday. Monday I'm picking up the rebuild kit from the local Kawasaki dealership. We'll see how it goes.
Old Mar 20, 2010 | 11:35 AM
Kerbbirds's Avatar
After you replace the needle and seat , turn the gas off when not in use and the new one will last longer.
Old Sep 28, 2010 | 02:56 PM
SteveEJ's Avatar
If there is Ethanol in your gas and you have a rubber tip on the float valve there is a good chance the Ethanol is eating up the rubber. That is what happened to mine.
Steve
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
ReconBayou
Oct 16, 2019 02:24 AM
exmotocrosser
Sep 13, 2019 06:12 AM
35dodge
Sep 29, 2015 09:40 AM
wrencher82
Sep 24, 2015 03:39 PM
