Throttle sticking
Old Mar 5, 2010 | 05:42 PM
mowerman1's Avatar
Default Throttle sticking
Can anyone help me on this. I have a Polaris 400 xpress. Takes a little while to idle down after you let off the gas. What is the jet setting.
Thanks for your help. I'm new at this.
Please work with me.
Mowerman
Old Mar 5, 2010 | 05:59 PM
popoman's Avatar
check to see if the throttle was manufactured by toyota...
anyway... jets cant be adjusted. Is the 400 express a 2 stroke? if it is it could be crank seals.
Old Mar 5, 2010 | 06:48 PM
4getful2's Avatar
2 and a half turns out 600-700 idle speed
check carb. spring and slide, when you have that apart, you can check throttle cable
Old Mar 5, 2010 | 09:06 PM
ftwflh's Avatar
Check the cable for frays look close at the oil pump
Old Mar 6, 2010 | 05:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does it idle down by it self after awhile? it not most likely a cable issue or adjustment. if it does idle down, it may be an air leak. imo
Old Mar 6, 2010 | 12:43 PM
mowerman1's Avatar
Thanks for help. Got it working. Now can you tell me the gas - oil ratio. Mine is injected and it is putting to much oil in the gas. Smokes real bad running idle and is fouling the plug out.
Thanks
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
