Brute force not starting
Old Mar 8, 2010 | 04:45 PM
Mastakilla's Avatar
Default Brute force not starting
Hello,
I have a 2005 Brute. I cannot get it to start. I've changed the spark plugs, cleaned the air intake, and even added a little carb cleaner. Their is power and it does turn over. I drained the battery as i was even trying to get it started. I'm not sure what the problem is or how it can be resolved?? Any ideas on what i should try??
Thanks
Old Mar 8, 2010 | 05:22 PM
mikel1's Avatar
Do you have spark and fuel to the plug? What is the compression at?
Old Mar 8, 2010 | 08:37 PM
Mastakilla's Avatar
There is a spark. I assume fuel is hitting it. Im not exactly sure what compression is at??
Old Mar 9, 2010 | 04:17 AM
hdkawi's Avatar
check your connections on your cdi under seat
Old Mar 10, 2010 | 10:52 PM
mikel1's Avatar
Try to start then pull spark plugs and check to see if they are dry, slightly wet or extremely wet.
Old Mar 11, 2010 | 10:20 AM
Hayashi's Avatar
Describe your starting procedure like where you set "choke" & "throttle".
Old Mar 18, 2010 | 12:39 AM
Mastakilla's Avatar
I've searched other forums and im going to adjust my valves. Thanks for the info.
Old Mar 18, 2010 | 10:00 AM
Hayashi's Avatar
If you've never adjusted the valves before, it is a very good idea to do it anyway regardless whether it will fix your hard starting problem or not. Another typical symptom for tight valves is that the engine would stall when you are coming to a stop even after engine is fully warmed up. Anyway, good luck.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
