trx 300ex shocks adj.
I have a 300ex 1995,I am 220lbs,how should I adjust the shocks.I ride on hard pack trails.Is there a tool to do this with? Do you adjust the shock for sag by your weight. Does any one know where I can get a owner manunal for this bike? This booklet should answer most of my ?
the 300ex only has preload adjustments, you should still use your weight as a factor in this adjustment, but theres only 5 different slots, more than likely it will be in the middle
but for most other shocks with rebound and compression it is usually 20% sag front, and 30% sag rear
i have a 300ex manual, idk if i can email it though cause i think its to big of a file
