12 volt accesory install again
Old Mar 14, 2010 | 06:45 AM
beadhead's Avatar
Default 12 volt accesory install again
i know this has been talked about a few times but still haven't found the answer. how can i use the unused electrical wire under right front fender on 2007 trx 420fm. i have done a few searches on auxilliary power installation and most people just say to wire directly to battery with in line 20 amp fuse. i am able to accomplish this but wondering if i could somehow hook into the wire under the front fender? not even sure if it is what the factory uses when installing power supply. do you just cut off the plug that is on the end or is there a matching plug i can buy and use? what type of plug is it? any help on this matter is appreciated.
Old Mar 14, 2010 | 07:17 AM
honda_420_ES's Avatar
Yes, you can use the wire under the right front fender. If you buy the 12v outlet from Honda it is plug and play. There is a plastic dud plugged into the connector. It is a pain to remove.
Old Mar 14, 2010 | 10:48 AM
beadhead's Avatar
thanks for the information. i will look into getting it from honda. i was trying to save a few bucks by buying aftermarket socket and install wiring myself. basically wanted to know the type of connector used or if i can splice into that wire? what is + and -?
Old Mar 20, 2010 | 04:25 PM
beadhead's Avatar
they want too much for it at honda here (@70$). i want to wire myself. would love to wire into a connector and just plug it in. looking for the type of connector to buy. if anyone has bought it i would love to know the name of it or where it was bought. might also look into splicing into that connection. anybody know which is + and -. does it matter? if not i guess i will just wire to battery with inline fuse... any suggestions or help is appreciatted..thanks
Old Mar 21, 2010 | 09:01 AM
SeniorCitizen's Avatar
This connector works for many ATV's to plug in whatever you want.
Just cut it in half and you have 2 pigtails.
Available at parts house or truckstops
Grote Industries: Trailer Connectors (Product #82-1034)
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
2many2ride
Sep 27, 2015 04:35 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
