fuel tank vent hoses
Old Mar 14, 2010 | 05:57 PM
Polaris500Sportsman's Avatar
Default fuel tank vent hoses
i wanna check over the vent lines on 06' sportsman 500efi and was wondering what all i have to take off to check them out. I'm pretty sure that it thats why it quits and wont stay running after it gets warm
Old Mar 14, 2010 | 06:05 PM
gaspumpcity's Avatar
Hmmm So do think the vent lines are plugged or just doing a routine maintenance thing?
Old Mar 14, 2010 | 06:15 PM
yeah im thinkin there either plugged or kinked some where
Old Mar 14, 2010 | 06:22 PM
If lines are not plugged or kinked then what? I guess you are getting a loud hiss when you remove the gas cap this is why you are going this route of checking the vent lines good call. Going to check fuel pressure too?
Old Mar 14, 2010 | 07:06 PM
yeah if checkin over and replacing the vent lines doesnt work then im gonna have to change out the fuel pump
Old Mar 14, 2010 | 08:44 PM
chuck_raduenz's Avatar
leave the cap loose if it keeps running its not the lines. but the vent line on my 08 is right under the under 16 sticker on the plastic. right under the gas cap. so you will need to remove the front cargo box, seat, side pannels, fender clips, and you may have to remove the headlight pod and handel bars as it was a pain to get my fenders off to check the fuel level tank sensor. but the hose runs into the stearing stem.
Old Mar 14, 2010 | 09:47 PM
ok thanks a lot for the help chuck, it sounds like a pain in the a$$ to take all that stuff off especially the front rack and fenders. greatly appreciated
Old Mar 15, 2010 | 03:42 AM
probly about 45min to take everything off. but heres a pic that i took when the fender was off to give way a better idea.
Old Mar 15, 2010 | 04:46 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
agreed by loosing the cap onthe tank would tel you if it's building pressure or not. if it stalled and you opened up the cap you would hear the pressure telling you that it's not venting. imo
Old Mar 2, 2020 | 12:03 PM
Breana Reshea Smith's Avatar
Okay the in this picture the clear hose coming from the gas tank running up underneath the speedometer and stuff is that a vent hose?
Attachment 19626[/QUOTE]
