carb question
Old Mar 15, 2010 | 12:17 AM
stangant's Avatar
Default carb question
My carb seems to leak fuel out of the bottom when gas is ran to it.. any idea of how to fix this small problem
Old Mar 15, 2010 | 01:01 AM
wildbill84's Avatar
Hi stangant,
may or may not work, but the problem could be that the fuel drain hose or outlet is open take a phillips or flathead and look for a screw close to the drain nipple on the bottom of your carb bowl and tighten it, in case its slightly open, causing your leak. good luck -justin
I attached a picture showing what to look for.
Old Mar 15, 2010 | 04:21 AM
wildbill84's Avatar
or it could be the carb bowl gasket depending on how old the carb is.
but you did write "out of the bottom" so it could be either.
Old Mar 15, 2010 | 05:41 AM
JeffinTD's Avatar
My guess is that you have a gummed up or defective float, needle valve, or seat.
This will cause the float bowl to overflow.
Depending on what machine you have, if it has a primer ****, deterioration of the seal there will also allow gas to flow into the float bowl.
Old Mar 20, 2010 | 12:24 PM
Kerbbirds's Avatar
Needle and seat are bad.
Old Mar 21, 2010 | 07:16 PM
git_it_rag's Avatar
The float is stuck and the fuel is overfilling the bowl. You need to take it off and tap it so it frees or take it apart and rebuild it while you are at it.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
