CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
ds 650 huge problem
Old Mar 17, 2010 | 10:45 PM
superds650's Avatar
Default ds 650 huge problem
my ds is coughing at three thousand rpm and when i get on it in fourth gear to fifth at about five or six it starts to back fire or it just dies. but it will start up agian i put new plugs and fuel filter on and the fuel filter wouldnt fill up
tried to get the carb out but the guy i bought it from striped the screws out. what do i do
Old Mar 18, 2010 | 10:19 AM
justme23005's Avatar
Pull the fuel line off the carburetor and see if fuel runs out when you turn the gas on.
Also, You should be able to check the rubber diaphram, without removing the carburetor.
Old Mar 19, 2010 | 11:17 PM
superds650's Avatar
fuel runs out. were is the diafram at? and there was a bunch of junk in the hose that connects to the carb.
superds650's Avatar
still dosent run right
Old Mar 25, 2010 | 10:52 PM
superds650's Avatar
ok now i have gas flowing out the tube on the bottom of the the carberatuer after running for a while it i run a screw in the hose will it still run good?
Old Mar 26, 2010 | 05:42 PM
maniacdriver's Avatar
You need to pull the carb off and check the needle & seat and the float level. If you had junk in the hose you need to clean the carb and blow out passages and jets.
Nondem
Feb 22, 2020 12:20 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Gtsordo
Jul 22, 2015 01:27 PM
hondarider1234
Jul 21, 2015 11:53 PM
