Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
40cc Eton viper jr
Old Mar 18, 2010 | 05:37 AM
Adamt313's Avatar
Default 40cc Eton viper jr
Hi this is my first but Im sure, not my last time to the sight. I bought my four year old a viper jr. It was running fine till I broke the pull start. Now it is fixed and I have no spark. I checked the safty tether and with the plug in I have a norm closed. I know this is correct. How do I check the Ignition coil, what should it ohm out at? How do I check the brake saftey. I took the cover off of the engine.It look like I need to take the hole top of the engine off to get the coil out.
If it was mine it wouldent be so bad, but the boy askes every day when I'm going to fix it.
Please help,
Thank You,
ACT 1
Old Mar 18, 2010 | 09:26 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Use the ohm meter to check the brake switch.
Disconnect the stator wire and ground that while turning the motor over. See if it sparks.
Old Mar 18, 2010 | 10:01 AM
Adamt313's Avatar
So just cross pos. and neg?
Old Mar 18, 2010 | 10:48 AM
LynnEdwards's Avatar
Electrical Expert
Is this quad pull start only, or does it have electric start? The wiring for these two are quite different. I can help if it is the electric start version. The pull start version just doesn't have enough info in the wiring diagram for me to know how it works.
Old Mar 18, 2010 | 01:43 PM
LT80's Avatar
LT80 Expert
Oh heck no.
Let's see what Lynn is onto.
Old Apr 27, 2010 | 06:05 PM
brent3359's Avatar
If you are just simply trying to verify the integrity of the ignition coil, then you could use a jumper wire to bypass all other circuit components and connect directly to the coil. Small engine basics: fuel,fire, and compression. Rid yourself of the electronics.
Old Jul 8, 2011 | 07:59 PM
chopp124's Avatar
disconect your speed limiter. thats been the problem on a couple of them i have worked on. this is the same as any other atv wiring system except the coil is right on the flywheel and gets it power from it instead of being remote off the cdi. same as a chainsaw or weedwacker. its only $65 to replace the coil and pickup if you suspect those. thats the green thing you are refering to
Old Jul 9, 2011 | 09:42 AM
LT80's Avatar
LT80 Expert
Hopefully that fella figured it out a year ago.
flyin-lowe
Dec 1, 2017 03:18 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Jr Wagner
Aug 21, 2015 07:56 PM
mbkirk
Aug 14, 2015 08:20 PM
