Here's an easy question...How do I put my 300ex in reverse?
Old Mar 18, 2010 | 09:47 PM
Danman2540's Avatar
Default Here's an easy question...How do I put my 300ex in reverse?
Just like the title says, how do I put my 300ex in reverse? I just bought it and didn't ask. I messed around a little and didn't figure it out so I thought I'd just ask you guys.
Old Mar 18, 2010 | 10:04 PM
TLC's Avatar
TLC
Like all Honda's,Put atv in neutral, squeeze brake ,push down red button and put atv in 1st. If I remember right . LOL
Old Mar 18, 2010 | 11:01 PM
Danman2540's Avatar
Theres a handle/lever on the left side of the engine for reverse. How do I use it?
Old Mar 19, 2010 | 01:32 AM
TexasRoadlawyer's Avatar
No Ruts, No Glory
tranny in neutral...
with left hand, push down on red button, then squeeze and hold clutch lever...THEN, with right hand, reach over to lever above the engine and pull up, should engage reverse
Old Mar 19, 2010 | 08:17 AM
Beastly 3hundo's Avatar
then to disengage it, just pull in the clutch, and push down on the lever, and ur back in neutral, Dont listen to TLC, hes old and rode utility quads lol jk, sorry man, i had to say somethin! lol
Old Mar 19, 2010 | 09:04 AM
Danman2540's Avatar
OK so I'm understanding that there is supposed to be a reverse button on the handlebars that I don't have?
Old Mar 19, 2010 | 09:41 AM
flytrip's Avatar
On my 250EX, trans in neutral, with right hand pull back on little **** on right side of machine, and click down on the shift lever.
Old Mar 19, 2010 | 10:13 AM
TLC's Avatar
TLC
LOL your right, no sports quads up here,the sportiest Honda I had was a 450 es Foreman.zzzzzzzzzz.
Old Mar 19, 2010 | 12:33 PM
Danman2540's Avatar
So is there supposed to be a reverse button on the handlebars? A lot of stuff had been eliminated on this bike such as the e-brake, ignition, headlight, and indicator lights, but I don't know why they would have disabled reverse. Like I said the handle on the engine is still there.
Old Mar 19, 2010 | 01:22 PM
budedm's Avatar
The reverse button on a stock 300 is on top of, and near the pivot point of the left lever (clutch lever). When that button is depressed it drops into a hole in the lever. There is a cable attached to the button. Then, with the button held down, the lever is pulled in like you would pull it to disengage the clutch. The cable that is attached to the button is now pulled. This is the cable that ALLOWS you to shift into reverse. Notice, the cable does NOT put the machine into reverse. It ALLOWS you to pull the reverse lever up that is on the left side of the motor. THIS is what actually puts the machine into reverse. Then you let the clutch out the same as any gear and you will be in reverse. So, there are actually 3 cables that go to the clutch lever. 1) The clutch cable 2) The reverse cable 3) The rear parking brake cable. If memory serves me, the reverse cable goes to the right rear of the engine near the bottom. Check that area and there should be a cable hook up. And maybe you actually HAVE the cable there but just need the button on the lever. Anyway, let us know how you make out.
