Tunig carbed BF 750
Old Mar 20, 2010 | 11:51 AM
Kerbbirds's Avatar
Default Tunig carbed BF 750
Been doing some tuning on the cold blooded , no starting, backfiring BF-750, here is what I have found to vastly improve them, the front carb comes from the factory with a 152 main jet, the rear carb has a 158 main jet, I have been putting a 158 in the front too, the other thing I have found is the air -fuel screws, under the silver plug on the bottom of carbs, drill the plug and thread a metal screw in it and pull the plugs out, set the screws at 2.25 turns out, the last one I did had one at 3/4 and the other was completely shut. While you have the front plastic off you can install the splash gaurds to keep the water out of airbox.
Old Mar 29, 2010 | 03:35 PM
Hayashi's Avatar
Above is a good info, especially on 05 model. However, if you are experiencing intake backfire, you may also want to install the richer needle jet (phycially narrower) in the front - use the same rear needle jet. In other words, you need two rear needle jets on the carbs. That will cure the intake popping & hesitation issue at low speeds.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
