400ex hard to start
Old Mar 20, 2010 | 04:47 PM
lillbro11's Avatar
Default 400ex hard to start
I have an 03' 400ex with a curtis sparks exhaust, 11:1 compression piston, k&n intake, 152 and 42 jets, and a shindengen cdi box.
I have been reading that its the cdi box that causes the weak spark and the hard start. Its about an inch or so shorter than the stock one. I put it on a friends bike and he had trouble starting his.
If this is the problem what cdi should I buy?
Old Mar 21, 2010 | 01:37 PM
burn400's Avatar
I've never heard any real compelling reason to not just run the stock cdi box. From what I gather the only upside is that you get a higher rev limit on a bike that stops making peak power well before the stock limit anyway.
Old Mar 21, 2010 | 03:43 PM
lillbro11's Avatar
sorry its not the stock cdi. its about an inch shorter and if its hooked up to my truck battery it starts no questions asked. it has a little higher rev limit on it and its supposedly off of some honda dirtbike. I'm not sure if it changes the ignition timing or anything and there are no numbers on it.
Old Mar 21, 2010 | 07:14 PM
git_it_rag's Avatar
maybe a valve clearance check should be done.
Old Mar 21, 2010 | 08:26 PM
lillbro11's Avatar
I only have about 6 hours on it since the last valve clearance check
MikeyBoyesq
Nov 27, 2020 02:44 PM
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
