Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Bombardier 50
Old Mar 22, 2010 | 09:51 PM
jwl0811's Avatar
Default Bombardier 50
Newbie here with a question. We have a Bombardier 50 that my 5 year old rode into some water. The left front end dropped into a rut and water went up and over the front fender. The motor died, but I was able to restart it after a few minutes. The issue I'm having is that it will idle, but as soon as I give it gas, it bogs down. We have checked the compression, carb, and checked for air leaks but haven't been able to track down the problem. I'm thinking it may be electrical. Any sugestions would be helpful. Thanks
Old Mar 23, 2010 | 07:39 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Please explain "checked the carb".
Old Mar 23, 2010 | 04:35 PM
jwl0811's Avatar
We took the carb apart and cleaned it out, checked the float, ect...
Old Mar 23, 2010 | 10:45 PM
LT80's Avatar
LT80 Expert
And removed both jets and made sure the lil holes are open?
Old Mar 24, 2010 | 08:18 AM
jwl0811's Avatar
Yes. Ran wire through and blew out with compressed air.
Old Mar 24, 2010 | 09:14 AM
LT80's Avatar
LT80 Expert
OK, did the stator get submerged? Maybe yuck in the stator.?
That has caused this before.
Old Mar 25, 2010 | 10:01 PM
jwl0811's Avatar
Dont remember checking the stator. Will do so, thanks!
Old Mar 30, 2010 | 03:55 PM
jday53's Avatar
Hi I am new here I have a 05 ds 50 And I am getting spark and fuel but it wont fire I have 70-75 lbs off compression is that enuff I just installed a new jug and piston rings and new gaskets any ideas???? thanks
Old Mar 31, 2010 | 08:32 PM
jwl0811's Avatar
I'm not a mechanic, but I can tell you that the compression in mine is around 120 -130. I don't know if that helps, just letting you know.
Old Mar 31, 2010 | 08:34 PM
jday53's Avatar
Yeah it does help but I still cant figure mine out as I Just put a new top end on this thing should have ooodles of compresion
ds-newbe
Jun 3, 2015 05:40 PM
bbehrendt
May 28, 2015 09:25 AM
AlaskaTRX
Dec 17, 2000 09:27 PM
Zorro
Oct 13, 2000 07:18 PM
ThreeWheelio
Sep 17, 2000 05:07 PM
