trx 250r head gasket ?
i'm trying to find out which year cr head gasket i can buy to fit my 89 trx 250r. i know it can be done can someone help. need my compresson. all the dealers around me told me they never heard of doing this. i told them when i find out i might tell then. probly not!!!! thanks kevin
Yes the 89 CR gasket will work. You can also buy a 3-part TRX gasket and drill out the 2 small holes so that the gasket comes apart. Now you can use the 2 thin parts as 2 gaskets. To make them seal better spray both sides a couple of times with Permatex liquid copper in a can.
I would think that your compression should be around 180psi.
I am running this setup right now with 2 base gaskets and a 21cc coolhead adn have about 185psi.
ERIC
aka TRX250R87
ERIC
aka TRX250R87
thanks guys for the input. nacs racing has a great site for 250r's gota check it out. i have taken apart a 3 piece gasket and used the two outer gaskets and had a psi of 210.
.50 over bore
my own port job
rad valve
38 carb
fmf pipe
thanks again kevin
.50 over bore
my own port job
rad valve
38 carb
fmf pipe
thanks again kevin
