What does the green wire mod on a trx450er do?
Old Mar 24, 2010 | 05:43 PM
Canadian07trx450er's Avatar
Default What does the green wire mod on a trx450er do?
I have a 2007 trx450er and I was told that cutting a green wire under the front plastics would help my performance. But what exactly will it do for the performance (top end, or bottom end or will it only eliminate the rev limiter) thank to anyone who could answer this for me!
Old Mar 25, 2010 | 09:19 AM
burn400's Avatar
It gooses your rev limit by 1000 rpm.
Old Mar 25, 2010 | 01:45 PM
mikel1's Avatar
It increases the power curve allowing for higher rpm's. If I'm not mistaken it helps on only on the stock cdi.
Old Mar 26, 2010 | 04:02 PM
burn400's Avatar
no...it doesnt touch the power curve. Really the only way you will see gains with this mod is if you have done or will do a more agressive cam. Otherwise the extra 1000 rpm's means nothing because the engine has ceased to make much power before the stock limiter kicks in anyway.
400H0
10
Aug 20, 2015 07:34 PM
frostphase
Aug 19, 2015 07:11 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
ScopeZ_
Jul 28, 2015 01:44 AM
DeFox500
Jul 26, 2015 06:32 PM
