400EX Axle Question
Old Mar 24, 2010 | 11:32 PM
CJM8515's Avatar
Default 400EX Axle Question
Im having some trouble trying to figure out if my axle is stock or not. It seems to have these odd spacers on it. Not sure if its stock or replacement, no markings as far as I can see and I bought it used and pretty beat up so I dont have a clue really..
I circled the spacers in the pic, there is one 3/16" or so and one about an inch wide.
Edit: It just dawned on me...
Perhaps this is an adjustable axle? And perhaps those spacers can be put inbetween the hub in any combination and the locknut put on?
Old Mar 25, 2010 | 12:14 PM
Dirtjunkie85's Avatar
If you take it off are there any markings/numbers were there carrier is? My brother has a G-Force axle and it has spacers like that.
Old Mar 25, 2010 | 09:15 PM
CJM8515's Avatar
Well final result is I changed the way the spacers fit.
I had originally wanted to put both of them on the outside of the hub, but the thinner 3/16 one can only be on the axle before you put the hub on as the splines run out there.
So I put the larger spacer on the outside the hub, IE: it now looks like AXLE-SMALL SPACER-HUB-LARGER SPACER.
It fixed the issue of the really offset wheels now, they still stick out maybe 1-2 inches but its much better than the 3 inches or so it had before, its near balanced like a stocker would be.
I did not get a chance to remove the axle from the carrier, but I would assume it can only be a few makes like durablue, rpm, g-force, etc and they all tend to have those spacers from what I can gather, so its an aftermarket thats for sure.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Huntingdeer
Aug 23, 2015 12:06 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
toonces
Aug 5, 2015 05:55 PM
yambam13
Jul 4, 2015 01:49 PM
