Transporting 2 quads on a 5x8 trailer
Old Mar 30, 2010 | 09:35 AM
mslwill1's Avatar
Question Transporting 2 quads on a 5x8 trailer
We have a Honda Recon that fit well on the 5x8 trailer, just purchased a Honda Rancher and trying not to purchase a new trailer. Is there a safe way to piggy back one vehichle? or other ideas on transporting the 2 quads would be helpful.
Old Mar 30, 2010 | 09:45 AM
NMills's Avatar
There probably is a way to piggy back em... Not sure how easy that's gonna be... is the trailer strong enough to hold the weight of the 2 machines??
Old Mar 30, 2010 | 09:48 AM
mslwill1's Avatar
Trailer has a weight limit not to exceed 2000lbs so yea it should be strong enough..just have to figure out how..
Old Mar 30, 2010 | 09:52 AM
budedm's Avatar
Can you load them sideways?
Old Mar 31, 2010 | 04:37 AM
zitaron's Avatar
....or an 8'x 6'6" flat trailer and run them up the side? strap them by the racks front and back .. they won't go anywhere you don't want.
Old Mar 31, 2010 | 07:37 AM
I would see if you could load the Rancher first straight in and then put the two front wheels of the Recon on the rear rack of the Rancher. I had a Kawasaki Lakota (about the size of a Recon and a Polaris Xplorer (about the size of a Rancher) and they fit in a T pattern on a 12x6 trailer. I currently use a 101"x12' snowmobile trailer so I can grab a buddy's machine too. We can fit 3 full size or even 2-up machines on it.
Old Mar 31, 2010 | 01:34 PM
NMills's Avatar
Here's a thought... tho may not be the best one... load the longer(from nose to tail) in first... but stand it up on it's rear end... Then drive the second one into it... make sure it's secured really good... or just stand the both of them up if you can.. Just a thought... but it may be a lot safer for you and everyone else to just buy another trailer...
Old Mar 31, 2010 | 01:45 PM
budedm's Avatar
Is it an enclosed trailer or open?
Old Mar 31, 2010 | 03:05 PM
scootergptx's Avatar
Supersock
Hired Gun!
I had a 5x10 flat trailer I used to load 2 on. It did have 15" tires, so there were the wheel wells to deal with. Somehow, it worked out for me they were positioned just right. I'd drive one up sideways onto the front of the trailer, the drive the other straight up from the back. But I don't know if there's gonna be enough room for them to fit with all fours on the trailer with a 5x8.
Old Mar 31, 2010 | 04:58 PM
BigCquadguy's Avatar
My friends, and I loaded up a 16 footer that really holds only 3 quads confortably on all four, But when you pop the front end up the trailer can hold up to 6 quads, and 3dirt bikes. Stand them both up, straight up on there rear wheels, and rear bumpers. you must turn off the fuel to prevent fuel leaks. Strape them down top to rear of trailer, and top to front of the trailer, and then togeather. Most axle hold 3500lbs per axle so you should be good. "Good luck"
