Oil change help
Old Apr 24, 2010 | 09:11 AM
Bonedaddycjh's Avatar
Default Oil change help
Im changing the oil in my kfx400 i did this many times and i recently was told instead of just putting oil back in the reservoir you should take the one allen key bolt off the side of the motor and add a little in there. Has anyone heard about this before? Thanks for any help
Old Apr 24, 2010 | 09:34 AM
TLC's Avatar
TLC
If its a wet sump after you drain the oil tank there will be a cup of oil remaining in the cranck case.
I drain the oil tank then start the ATV for like 20 seconds and the additional cup of oil in the crank will pump into the oil tank and drain out. Simple and quicker.
Old Apr 24, 2010 | 09:38 AM
Yeah i knew about that but i was asking about the case itself should you put oil in that or just fill res up and it will work its way there i always thought
Old Apr 24, 2010 | 09:43 AM
TLC's Avatar
TLC
Just add to the oil tank,it will instantly pump though the entire system.
Old Apr 26, 2010 | 02:24 PM
Thanks for the help thats the way i usually do it but just heard a rumor. Thanks again
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Alex G.
Sep 11, 2017 11:38 PM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
