500 HO overheat issues
Old Apr 29, 2010 | 04:03 PM
tonythom's Avatar
Default 500 HO overheat issues
I just got this 02 sp and the hot light come spon when you ride. It can idle with no problems. The previous owner bypassed the temp sensor because it went bad. It now has a toggle switch. I looked to clean the radiator and noticed with the fan on air was blowing out the front of the radiator. Is it possible he wired fan wrong and caused it to run backwards. Can definitely feel air blowing forward thru the rad when you put your hand in front of it. This would cause zero air flow when riding.
Also had to adjust float. It still spits alittl gas out when you ride it but not much. HAd the carb off about 6 times to get it that good, before either flood out after 5 minutes of riding or getting no gas at all. Thanks for the help. TonyT
Old Apr 29, 2010 | 05:13 PM
4getful2's Avatar
the stock fans are design to pull air thru,so whatever they did is not correct.
Old Apr 29, 2010 | 07:45 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Air should be pulled through and make sure the radiator is CLEAN.
Old Apr 29, 2010 | 08:23 PM
tonythom's Avatar
Is it possible to wire the fan wrong and change direction? Being DC I would think so.
Old Apr 29, 2010 | 11:16 PM
TLC's Avatar
TLC
Yes if he monkeyed with the two wires it will cause the fan to turn the wrong way.
I tested my fan once if i changed the + - DC source the fan will run in opposite directions.
The fan is made by SPAL and there all pullers.
Old Apr 30, 2010 | 04:56 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like he reversed the wires to go backwards for sure. just change the wires or put a new sensor in it.
Old Apr 30, 2010 | 09:23 AM
TLC's Avatar
TLC
These Rad themal switches will work and are found much cheaper at a auto parts store but you will have splice your old connection from the Polaris (4010161) thermal switch.
Napa FS147
Wells SW526
Blue Streak TS-127
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
Unzzy66
Jul 11, 2015 10:01 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
