Fuel Coming out Air Pressure Sensor
Old May 11, 2010 | 01:02 PM
jeprsqr's Avatar
Default Fuel Coming out Air Pressure Sensor
I have a 700 Efi arctic cat ths has ?had fuel come out of the Air Pressure Sensor ??? No error codes ???
I was on the trail last tuesday turned the key on and notised some gas spitting up to the bottom of the control panel. NOT GOOD ???
But doesnt seem to affect the ATV .
Any suggestions PLEASE.
Old May 11, 2010 | 02:31 PM
cupsz71's Avatar
Cool
If I'm not mistaken, there's a fuel overflow/breather hose that runs up under the instrument pod in amongst the wiring bundle. I've seen numerous posts about seeing/smelling fuel up around the pod w/EFI quads.
Not sure what the fix is.....but you could crack your gas cap and see if any pressure has built up? I'd also check to see if any of the fuel lines are pinched.
my .02¢
Good luck
Old May 17, 2010 | 10:22 PM
Lil'Slim's Avatar
The problem is overfillig the tank, just fill to the bottom of the neck, not to the top, and you should not encounter this problem anymore.
bzdok1234
30
Feb 23, 2016 01:55 PM
Unzzy66
Jul 11, 2015 10:01 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
