Ds650 swing arm
Old May 12, 2010 | 05:28 AM
rockey07's Avatar
Default Ds650 swing arm
Hey
Im looking to replace my bearings in my swing arm, I was just wondering if there are anysuprises along the way will attempting to do it? Or is it pretty straight forward.
Im having play in the wing arm so im guessing its the bearings
any help would be greatfull
Thanks
Old May 12, 2010 | 08:01 PM
cobra7421's Avatar
its pretty simple. i just took mine apart the other day. first take the clip on the brake hub side off, then take the threaded lock nut off. (thats a little hard if you don't have the right tool but i just used a flat head and a hammer for that). next the brake hub should slide off, if not tap it with a rubber mallot so you don't scar the brake hub. next there is a lock washer that requires special plyers but i was able to get it off with out them. next take the brake caliper braket off, next take your brake side wheel hub off and your axle should slide right out to the right. now u have access to your bearings. mine came right out cuz the were very worn. good luck and i hope this helps.
Old May 12, 2010 | 10:50 PM
TheStir's Avatar
Started riding ATVs in 1974!
Swing arm pivot or axle bearings?
Old May 13, 2010 | 05:00 AM
rockey07's Avatar
Its the swing arm buchings, I guess it doesn't have bearings. I they say with bushings its suppose to have some play in it, im not sure. what do u guys think?
Old May 13, 2010 | 08:23 AM
TheStir's Avatar
2004 and up had bearings... mine is a 2000 and has bushings, but when I set the pivot bolt up to specs I have no play. Do you have a manual for setting the bolt? If not I will look up the steps and post it here for you.
Old May 13, 2010 | 01:20 PM
yammimoose's Avatar
Default re:
Words of advice...
Anytime you take apart or replace anything related to the Swing Arm make sure you have the correct tool to tighten and make certain you toque according to the manual. I didn't in the past. It cost me 2 Front Bolts and many bearings in the rear...
Everything needs to be seated correctly before applying the final toque.
-Moose
Old May 17, 2010 | 05:00 PM
rockey07's Avatar
i dont have a manual for my bike
that would be great if you could post that
thanks
MRDS650
Feb 22, 2026 11:26 AM
fd24
Jan 16, 2019 08:59 AM
Jul 28, 2015 12:12 PM
Bell21
Jul 28, 2015 06:52 AM
VRRRRT
Jun 27, 2015 09:38 AM
