Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
kuzuma mini falcon 90 PLease hElp
Old May 28, 2010 | 04:12 PM
mrscary4791's Avatar
Question kuzuma mini falcon 90 PLease hElp
Can any one help me It takes forever for it to start and some times it wont start at allI have checked all the conections I got good spark the carb is sucking great just wont start when does it will run fine but once it sets here we go again dont wont to burn the starter up so im letting it set till some gives me some advise to check other possiabilities I have tried starting fluid in the airbox but not any different
Old May 29, 2010 | 10:01 PM
LynnEdwards's Avatar
Electrical Expert
Have you ever adjusted the valves?
Valves tighten with wear, and tighten even more when cold. So the classic symptom for tight valves is hard starting when cold, eventually leading to no starting.
Old May 31, 2010 | 01:36 PM
No i havent ill do that and see if it works do you now what clearance I need to adjust them to?
Old Jun 1, 2010 | 12:21 AM
Electrical Expert
I don't know what the spec's are for your engine. Perhaps someone else knows.
I set my 150cc quad to 0.004" on both intake and exhaust when the engine is cold. If you find your valves are tighter than that then I'd loosen them up to 0.004 and see if it makes a difference. Slightly loose valves are noisy. Tight valves make a quad hard to start.
Old Jun 6, 2010 | 09:31 PM
It worked adjusted the valves to .004 and it fired right up thanks a lot
Old Jun 6, 2010 | 11:10 PM
Electrical Expert
Glad it's running again.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
