ATC185 wont run weak spark
Hi,
I've got a ATC185 that wont run!!!!! it seems to have a weak spark, if i turn the throttle stop right in and use a brand new plug it will run (rev high) 2 mins and then die once . if it doesnt go 1st or second pull then the plug will get soo wet and no spark is then present.
Any ideas????
Any ideas????
Swapped out the stator coil yesterday and I have fitted new connector ends on the wires, but still the spark seems weak.
It ran again for a short time by openning the throttle stop wide open, however it then stalled once i tried to lower the tick over. Plug was wet and black and no spark was present until i cleaned the spark plug again????
Anyone had similar faults, as I am pullin my hair out with this one!!!!!
Has the bike been running fine prior to this or did you pick the bike up in this condition?
What's the ohm reading between the black wire from the stator and the bike frame?
What's the ohm reading on the primary and secondary coil?
(use this manual if you don't have access to one already)
http://72.52.143.80/~trikes/Manuals/ATC%20manuals/Honda%20200E%20Big%20Red%201982-83%20CD.pdf
Have you performed a compression test?
Based on the information you've given it would sound as though you're running rich. You'll want to check your carburetor and how it's tuned. Check the cir-clip is on the throttle needle. It should be on the 3rd notch. Also, your pilot screw, may want to screw it all the way in and then back it out 2 and 1/2 turn.
Hi Thanks for your comments!
I got the bike in bits about 6 months ago, but was told it has had new piston & rings and it compression tested OK. When i first bought it, it started more or less straight away and It had been starting first or second pull with a new plug althought after running it about 3 or 4 times it would not run or spark and the plug would be very wet and black.
So far Ive switched out the stator and ignition coil and changed the wiring end connectors in the hope that the spark would at least get a little stronger. but unfortunately no luck!!
I've not yet taken any ohms reading (due to mot havin a manual) thanks again!!! but hope to do so in the next couple of days.
Question: does the 185s (pull start only) generally have a a large blue spark? should a wet plug make it loose its spark as mine does?
Thanks in advance!
Peter
Thanks in advance!
Peter
Hi,
Just done the electrical checks
Stator 191 ohms
Primary coil 0.1ohms
secondary 4.3 ohms
Spark was quite small just about blue jumping about 0.5mm.
tried a different pug cap
also cleaned all the carb and jets out
And it would it still would not run!!!!
Stator 191 ohms
secondary 4.3 ohms
im gonna have to agree with mikel1 on this ... sounds like its dumping WAY too much fuel into the motor ... when it fires up is it smoking black ?
Its not smoking when fires up, but it just wont tick over either. ive tried another carb on it ithout success. it ran better before i put an air box on it but still wont go even if i remove it.
Im baffle'b
Im baffle'b
Just wondering what jets do you have in the carb right now? Which choke setting is it on (there are 3)? needle setting? Have you gone through it? My 185 starts with 1-2 pulls even after sitting, it has a blue/yellow spark using a ngk or champion plug (ngk=better). Another carb wont do much if it wasn't jet correct. If your switching out ignition parts with no luck time to try something different
Silly question but have you changed the plug?
Hi,
Thanks for responding I thought everyone had given up on me!
Yeah I have tried new plugs it did work a couple of times initially but soon sooted it up.
I got that fed up with is about a month ago that I decided to buy a 200s instead on ebay. Guess what 2 days after i got it home I got the same issue with this one too!
. freakin sooty plugs and wont start
However, I have just bought a new carb and fitted it yesterday and it seems to be fixed...... not checked the plug yet thou, but it has started about 10 times over the last two days
Also when i bought the carb i got such a good deal so I decided to get another for my 185. fingers crossed it will do the same job in fixing it. As the symptoms were both the same.
.Also when i bought the carb i got such a good deal so I decided to get another for my 185. fingers crossed it will do the same job in fixing it. As the symptoms were both the same.
