KFX 450R starting and ideal problems?
Old Jul 7, 2010 | 11:27 AM
Dirtjunkie85's Avatar
Default KFX 450R starting and ideal problems?
Hi I have a KFX450R 2008 model it has been great but I was riding the other day and I let off the throttle and it just died so I tried to start it back up and it would not start unless I gave it a little throttle and then would die again if I let completely off the throttle?? as soon as the machine cooled it will start fine without any throttle?? Keep in mind this is fuel injected so you shouldn't have to give it any throttle any help would be appreciated thanks.
Old Jul 7, 2010 | 08:55 PM
Doctorturbo's Avatar
GOT BOOST!
A WAG, you have problems with the TPS.
Old Jul 7, 2010 | 10:19 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Does your F.I. blink or stay on?
Old Jul 9, 2010 | 12:29 AM
duster's Avatar
It can be so many things.
You'll have to start by checking your TPS per the service manual...
And you may need to check your valve clearance.
Think it has enough time on it to need an adjustment?
(this will cause hard hot-starting)
A bad coil will sometimes only manifest itself when hot too.
I gotta guess TPS from your description though.
Old Jul 21, 2010 | 11:55 AM
I dont have many hours on it all it almost brand new so I am sure the valves should be fine what is TPS?
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
clsharky
Jun 8, 2015 11:38 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
