Bayou 220 fuel problem
Old Jul 19, 2010 | 11:48 AM
49erjimmy's Avatar
Default Bayou 220 fuel problem
Have a 1995 Bayou and a few hours after it is ridden it starts leaking fuel out of the black tube coming from the bottom of the carb (float bowl?) It will continue to leak until the tank is empty if I don't turn off the fuel. Anybody know what the problem is and how to fix it? (the tube attaches to a fitting at the bottom of the carb that goes about an inch up into the carb above the floats). Thanks
Old Aug 19, 2010 | 10:32 PM
Ludador's Avatar
I just had this same problem with my 02 220. I rebuilt the carb and it hasnt leaked any gas so far. Carb rebuild kits are relatively cheap also.. ranging from 12 bucks and up. Btw what causes this is the float gets stuck so you will need to grab some carb cleaner and clean the pin and float
Old Sep 14, 2011 | 03:25 PM
brandon.thaggard's Avatar
can someone tell me where all the fuel lines go on a 89 bayou 220. and where the other breather line go to. i just got a bayou and doin a total rebuild on it, and need a little help. thanks
Old Sep 15, 2011 | 09:44 AM
Hayashi's Avatar
In your case, probably all you need is either cleaning or replacement of the rubber tipped float bowl valve that is not seating correctly and letting in fuel into the float bowl continuously. Loosen 4 screws, remove the float bowl and inspect the valve and the float assembly.
Old Oct 29, 2017 | 06:21 PM
Stuey9's Avatar
I have a bayou 220 and have worked on many other machines. My main thought is that the floats are stuck or the fuel line is on a vent line, believe it could happen. If the float is stuck the gasoline comes of of vent lines and flood your wheeler. If the lines on a vent that could happen to. One other thing is the drain screw on the bottom could be loose
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
Mikea1978
Jul 4, 2015 12:37 PM
