warrior wheel spacers?????
Old Aug 6, 2010 | 11:38 AM
driftking's Avatar
Default warrior wheel spacers?????
ok, so im wanting to widen my front end on my 88 warrior. ive looked at wheel spacers and extended a arms but a arms are just too much. i was curious what is the widest wheel spacer i can get???
Old Aug 6, 2010 | 01:55 PM
twho's Avatar
you may be able to invert your rims ive done it on a blaster, and raptor 250? you may need a shorter valve stem?
Old Aug 6, 2010 | 02:13 PM
Wreckr's Avatar
You can definitely get offset yamaha rims. I had them on my old warrior for my front dune tires. They were light weight aluminum, but I'm sure they make steelies for it. I believe my offset was 1.5" or so. so 3" overall. That's pretty good spacing. I have them on my DS650 now.
Old Aug 6, 2010 | 04:35 PM
driftking's Avatar
will they give me that wider look?? how much would extended a arms cost me? any one have an idea?
Old Aug 8, 2010 | 04:23 PM
beastlywarrior228's Avatar
spacers are fine but dont go more than 1.5" on each side
Old Aug 8, 2010 | 05:53 PM
91Warrior357's Avatar
you got 3 good options get the ASR extended a arms which are sweet and only like 400 something...also you can replace ball joints with those, you could flip your rims, the front will require you put the valve stem on the other side or get one thats really short i guess, you can weld up the hole from the original valve stem or just flip it over like alot of people do then just drill the hole for the new valve stem...or get spacers, only thing with spacers is it adds stress to alot of parts and i too would suggest not going wider then 1.5 on those
Old Aug 9, 2010 | 10:13 AM
driftking's Avatar
thats only going to give me about 3'' total. will it be a noticable wider look? i wanna get that wide look without spending a bunch of money on it.
Old Aug 10, 2010 | 02:23 PM
oh ya its noticeable
01ssls1
Sep 22, 2015 06:50 AM
meddy0388
Sep 9, 2015 06:41 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
