99 Sportsman 500 overheating
Old Aug 15, 2010 | 09:02 PM
msbrockman's Avatar
Default 99 Sportsman 500 overheating
Gents, Thanks for reading this. I couldn't find a post similar to it. My atv has the correct level of coolant, the fan seems to run fine, the radiator fins are not plugged with mud or weeds. Under normal riding conditions (no hot rodding, level ground at about 8000 ft of elevation) and after the atv is up to normal operating temp, the atv will overheat when it idles for more than a couple minutes (the red light comes on). After I ride it for a few minutes, the red light will go off. This problem is very repeatable. Any suggestions would be appreciated. I am thinking it could be the thermostat or water pump???
Thanks!
Old Aug 15, 2010 | 09:37 PM
TLC's Avatar
TLC
Maybe the there air in the coolant system causing a air lock and it needs to be bled/burped out.
Also the thermostat in the side of the motor at water line is not fully opening.
OR
Thermal switch that tells the fan to come on and off may need to be changed,it screws into the rad. But if fan works I doubt its that.
Part #6 in pic, $28.58 to buy. OEM motorcycle and ATV parts from Honda, Yamaha & Polaris – Cycle Parts Warehouse
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
