Kawasaki Lakota- More chain issues
Old Aug 23, 2010 | 05:53 AM
arrowsmith's Avatar
Default Kawasaki Lakota- More chain issues
Ok, so I figured out that, not only do you need to remove the nuts from the bolts when tightening the chain, but you also need to remove the bolts to get the carraige to loosen. Now the problem is that when I rotate the carriage a few new problems arise. The arm holding the brake caliper will not allow me to tighten the chain, and when I take the bolt out of the arm the caliper spins and the chain tightens, but now the caliper bolts are no where near in line so I am not able to reattach the caliper, AND, the caliper is in a position directlyover and close to the bolt that tightens the carriage preventing me from getting at it. What to do now? Arrowsmith
Old Aug 23, 2010 | 07:21 AM
hillbilly_racer's Avatar
Sounds like you are beyond the adjustment range of the bearing carrier. May be time for a new chain and/or sprockets. It may also be possible to remove a link from the chain but only if it is still in good condition.
Old Aug 23, 2010 | 01:34 PM
arrowsmith's Avatar
Thank you hillbilly. I figured that it may be time for a chain. How do I tell if I need sprockets as well as a chain? Thanks again. Arrowsmith
Old Aug 24, 2010 | 06:17 AM
The teeth on the sprockets should look the same on both sides. As the sprocket wears you will begin to see the side that the chain pulls against start to get a dip worn into it. If you see this, the sprocket definetly needs replaced. Actually, to get the most life from your chain and sprockets, you should always replace them as a complete set anyway.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Unzzy66
Jul 11, 2015 10:01 PM
Sjrpp
Jul 5, 2015 09:04 PM
