Is your 750 brute force burning oil?
Old Aug 26, 2010 | 10:10 AM
player9772's Avatar
Default Is your 750 brute force burning oil?
I have an 06 brute force 750 that was burning oil and backfiring and popping and decel. After I spun a rod bearing and smoked the crank I finally found out why this was happening. A valve seal lifted off the cylinder head on an intake valve of the front cylinder. Oil was getting pulled down the valve and into the cylinder. The burning oil left a whole lot of carbon build up on the valves, causing the backfiring and popping. Just figured I would share my story so any of you with a brute force that is burning oil can fix the small problem with the valve seal before you wipe out a crank.
Old Sep 2, 2010 | 11:20 AM
Dirtjunkie85's Avatar
Thanks for the info
Pgbama11
Jan 16, 2016 08:19 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
