2 Stroke smoke
Old Aug 26, 2010 | 07:14 PM
dawgsfan's Avatar
Default 2 Stroke smoke
So I've had hella problems with my '98 300 xplorer since I took it to the local polaris repair guys. Paid to have the carb cleaned. Had to take it back 3 times to get it semi right. Anywho, it had a rough idle at start up so I adjusted the pilot screw to spec 1 1/2 turns out (they had it 4 turns out) and it cranks fine now. It puts out quite a bit of white smoke when cranked and when I put the throttle to it. Is this normal for a 2 stroke? Or should I be concerned about it running rich?
Old Aug 26, 2010 | 09:08 PM
sugarhead's Avatar
Are you loosing coolant by any chance,Better on the richer side for a 2 stroke I feel same w a 4 stroke.If you go to lean the bike runs hot an will blow up,run it too rich and it will blubber and can run hot too.But your safety margin is better on the richer side of things.Usually white smoke is coolant or transmission fluid,but the tranny an engine are seperate I believe.I have a 03 polaris tb 400 and I love it.
Old Aug 26, 2010 | 10:16 PM
ramman67's Avatar
Default 300
the 300 2 stroke is air cooled.
Old Aug 27, 2010 | 09:43 AM
tyler1blaster's Avatar
crank seals
Old Aug 27, 2010 | 06:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you premixing or is it injected oil? hows the compression? it wouldn't be smoking extremely bad, but some as it's a 2 stroke.
Old Aug 28, 2010 | 08:08 AM
dawgsfan's Avatar
It's injected. What is compression? I've heard a lot about it but have no idea what it is/does. How do I check it?
Old Aug 28, 2010 | 08:22 AM
dawgsfan's Avatar
Looked it up in my Haynes book and it explains checking 4 stroke but not 2 stroke compression. Is it the same?
Old Aug 28, 2010 | 08:40 AM
sdm111's Avatar
2 strokes or 4
Originally Posted by tyler1blaster
crank seals
Yep You're burning tranny oil
Old Aug 28, 2010 | 09:03 AM
MrMarty51's Avatar
Would bad crankshaft seals allow transmission oil to get into the engine???
I do`nt know,just asking.
If the transmission is seperated from the engine with a primary belt I do`nt see how it could,if the trans. and engine are in the same box then there would still be a primary drive from the engine to the transmission seperated with a primary chain/belt housing so I still do not see how transmission oil could get into the engine via bad crankshaft seals.
If the chaain housing is wet then it could get primary chain housing lube into the engine due to bad crankshaft seals.
Old Aug 28, 2010 | 09:25 AM
sdm111's Avatar
2 strokes or 4
Yeah you're right, my bad. I know my Honda 2 stroke when crank seals go bad it sucks tranny oil, it has no chains or belts just gears.
