i need help with my 05 kfx 400
Old Sep 12, 2010 | 11:59 AM
firefighter534's Avatar
Default i need help with my 05 kfx 400
i noticed my fan was not comeing on so i checked my raidator and there was no warter or anything in it so i put some distealed water in it and the water mixed with my oil and went through my whole motor even the carb and the air box so i took the motor apart and thought i might have had a cracked head or jug but they both looked good so then i thought it might have been a head gasket but it looked good to so i dont know what it is will some body please help me
Old Sep 13, 2010 | 07:23 PM
player9772's Avatar
check your water pump shaft seal, take the cover off your water pump and unthread the impeller, it comes off with a 10mm socket. there should be a spring loaded mechanical seal right behind it, be careful not to break the carbon mating surfaces they are very brittle. the shaft seal will be right behind that. its a long shot that is your problem but it sounds like u got the top of the motor covered.
