Timberwolf rev issues
Old Sep 12, 2010 | 08:25 PM
wvdealz's Avatar
Default Timberwolf rev issues
bought a 1999 4x4 Timberwolf that ran great but smoked like crazy. I took it apart, changed the rings, and then cleaned the carb since the bike had been sitting for a while. After I got it back together, the bike started and idles fine, but when you rev past 1/2 to full throttle, the bike starts reving up and down, as if I was puching the throttle open/close, and won't stay revved up. Like I said, when you leave it at idle, it purrs like a kitten. There is no sputter and no back firing. I checked the valve lash and the timing to ensure it is not out 180 degrees and all checked out fine. Anyone have any help please!!!
Old Nov 27, 2010 | 10:26 PM
budd68's Avatar
i would take that carb back off and see if the slide in the carb. is working free and not sliding hard.
Old Jan 6, 2011 | 01:05 AM
beaverhunter420's Avatar
sounds like your floats maybe sticking?? or maybe your getting air from other then the air box....when its idling try spraying wd-40 or ether around the head and carb manifold if it starts reving up its an air leak
Old Jan 6, 2011 | 05:24 AM
team_realtree's Avatar
I`ve had problems like this on mine and it ended up being an air leak. Check all the mating surfaces of the carb by spraying something like wd-40 at them and listen for the RPM`s to level out.
COFatboy
May 2, 2020 12:06 AM
Jenn1
Sep 8, 2015 09:16 AM
cody500ho
14
Aug 14, 2015 05:03 PM
WesTech
11
Aug 11, 2015 07:55 AM
Unzzy66
Jul 11, 2015 10:01 PM
