How do you remove axle on 04 recon 250 ES?
Old Sep 14, 2010 | 10:30 AM
sjohnson93024's Avatar
Default How do you remove axle on 04 recon 250 ES?
I need tips on removing and replacing rear axle on 04 honda recon 250...does it knock out or do i have to open rear end?
Old Sep 14, 2010 | 11:09 AM
TLC's Avatar
TLC
It just knocks out and is held by a compression ring like on all ATVs. Go on you tube and look up "ATV axle removal" or "CV boot change" and see one being done,there all done much the same way no matter what brand or model.
Old Sep 14, 2010 | 03:09 PM
Thanks...I have heard both ways knockout and open rear end...never thought about you tube....where is the compression ring located?...behind the 2 locknuts?
Old Sep 14, 2010 | 03:43 PM
TLC's Avatar
TLC
OOOPs, sorry never read your post right, I thought you meant a CV axle which a recon does not have.
Still a you tube search should still work.
Heres your rear in a parts diagram if that helps.
Old Sep 14, 2010 | 04:04 PM
thanks...yeah it is a straight shaft axle no cv's I have the diagram already but still don't know if it knocks out or have to open rear end...trying not to open if I dont have to....appreciate your help.
Old Sep 15, 2010 | 07:35 AM
ddrumman2004's Avatar
The service manual states to remove the axle by tapping with a rubber hammer from the left side as sitting on the atv. Of course this is after everything else that needs to be removed is removed.
The rear end does not have to be opened.
Old Sep 15, 2010 | 09:50 AM
TLC's Avatar
TLC
By the above pic I would say those are the parts between 23 and 14.
Old Sep 15, 2010 | 12:17 PM
what else has to be removed? I mean beside the wheels and one side of hub.....Thanks for the info.
Old Sep 16, 2010 | 06:46 AM
Just the wheels, hubs and brake assembly. Then tap it out from the left side.
Hunter100us
Oct 7, 2015 11:46 PM
Cantbuytime
Aug 16, 2015 09:13 PM
Hondamx751
Aug 13, 2015 01:06 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
