Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
Eton fuel leak
Old Sep 14, 2010 | 04:52 PM
vetteman84's Avatar
Default Eton fuel leak
Bought a used 2005 eton viper 150r. wasn't running. replaced fuel petcock, fuel lines, spark plug. took carb apart and cleaned it. Put everything back together and it started right up. I let it run for about 15 mins, then shut it off. Tried to start it a couple hours later and wouldn't start. noticed that there was fuel dripping on the ground, which is coming from the air filter case. Fuel appears to keep flowing into the carb, then into air case. pulled spark plug, and it is wet also.
Any Ideas or suggestions?
Old Sep 14, 2010 | 06:22 PM
Jaster94's Avatar
i think your float is stuck. i store my atvs with the valve in the off position. you may check your oil also.
Old Sep 15, 2010 | 08:47 AM
LT80's Avatar
LT80 Expert
Yes, a "fuel by the petcock" issue.
Jaster is correct, better check the oil to make sure it hasn't filled the bottom end w/gas.
Old Jan 7, 2011 | 09:33 AM
LT80's Avatar
LT80 Expert
Fuel is going by the float needle.
Try cleaning the carb.
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Jul 29, 2015 10:57 PM
Unzzy66
Jul 11, 2015 10:01 PM
