removing axle on recon 250
Old Sep 16, 2010 | 05:53 AM
sjohnson93024's Avatar
Default removing axle on recon 250
when removing the axle on 04 recon 250 es will the main gear in the rear end stay lined up in order to push the new axle in?....also when removing old axle will the bearings be pulled out?
Old Sep 16, 2010 | 06:41 AM
ddrumman2004's Avatar
Yes. Just make sure you drive the axle out from the left side as sitting on the atv.
When installing the axle, you tap it in from the right until it seats. You have to install a new o-ring on the axle, coat it with grease and add molybdenum disulfied grease on the center splines.
Then just install the brake and hubs etc.....all this info is from a 2005-2009 factory service manual. I can't imagine there is any difference in the 04-05 rear axle.
Hope this helps.
Old Sep 16, 2010 | 07:04 AM
Thanks for the info...
Old Sep 17, 2010 | 09:40 AM
No problem! Good luck and keep us posted!
Hunter100us
Oct 7, 2015 11:46 PM
Cantbuytime
Aug 16, 2015 09:13 PM
Hondamx751
Aug 13, 2015 01:06 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
