Replacing clutch bearing in 04 recon
Old Sep 19, 2010 | 09:17 AM
sjohnson93024's Avatar
Default Replacing clutch bearing in 04 recon
How would you replace one way clutch bearing in 04 recon 250 es?....where is the clutch cover located?......Is it a major deal or can someone with mechanical abilities do it?
Old Sep 19, 2010 | 08:59 PM
papa hogg scoot's Avatar
Loved
Community Favorite
The best way to do this is turn fuel off, lock parking brake, get help to stand recon up on the end [rear rack]. the case cover that has the shift motor mount it has to come off, then the centrifuial clutch has to come off and the bearing in the clucth drum is what needs replaced,note the direction the bearing is in because if you put in backwards it wont go...
coolguy420
Jul 10, 2015 01:17 AM
jettman
Jul 6, 2015 12:16 PM
Mikea1978
Jul 4, 2015 12:37 PM
bikedad3
Jul 2, 2015 02:15 AM
Dieseltrash
Jun 6, 2015 09:53 PM
