Whens the best time to check oil.
Old Sep 24, 2010 | 09:12 AM
sjohnson93024's Avatar
Default Whens the best time to check oil.
When is the best time to check oil?.....Cold engine or hot?
Old Sep 24, 2010 | 09:17 AM
TLC's Avatar
TLC
Both as long as the motor is not running.
Old Sep 24, 2010 | 09:58 AM
Jerkyking's Avatar
My maintenance manual says after the engine has been ran for 5 minutes.
Old Sep 24, 2010 | 10:10 AM
TLC's Avatar
TLC
I know you have to run the motor,for a short time after you just change the oil,to get the oil through the oil filter before checking the level. After that it is just like a car, just check it when it's part and shut down.
Old Sep 24, 2010 | 10:20 AM
scootergptx's Avatar
Supersock
Hired Gun!
Anytime after 8am on Saturday is good, I sleep in then.
The difference between checking it cold and hot won't be that much. If the stick is dry, it's gonna be dry either way and you should have checked it sooner.
I always checked mine before I started them. If for some reason there wasn't any oil in them, letting it warm up wasn't going to do it any good.
Old Sep 28, 2010 | 09:18 PM
angler's Avatar
It really depends on which atv you are checking. I know on the Rubicon and the Rincon, you need to let the engine idle for about 5 minutes then check it. If you check it when it is cold, it will be low on the dipstick but if you add any, there will be too much. I made that mistake once, will never happen again.
I am not sure on the other Honda models.
Old Sep 28, 2010 | 09:25 PM
JeffinTD's Avatar
Some of these Honda engines are dry sump, or semi-dry sump, so letting it idle for 5 minutes or so followed by sitting for a couple minutes is necessary to get a correct reading.
SOLOLUCKY
Oct 4, 2024 09:09 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
garyt1975
Jun 5, 2015 08:53 AM
