4 trax fuel pump problem
Old Sep 29, 2010 | 06:46 PM
r good's Avatar
Question 4 trax fuel pump problem
this 1989 350 4 trax quit running and i found that the fuel pump was very
warm. i rmoved the pump and hooked it to a battery and it fluttered ok.
then i checked the voltage of the leads going to the pump and the reading
was 5.8 volts. can anyone help me? is there a pump relay or some kind of
electrical control box?
Old Sep 29, 2010 | 07:46 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Yes cut off relay is just under the right rear fender setting on quad.[inside an triangle box].. I would use an curcuit light tester on the black with blue stripe at pump harness[red lead on this wire and blk lead to ground] then turn ign.key on push starter button then curcuit light should light up if voltage is okay. relay works off of cdi[ign.brain] everytime cdi sparks it turns the relay on then pump.Check out then get back with us.
Nondem
Feb 22, 2020 12:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
