400ex hotcam question
Old Sep 30, 2010 | 06:16 PM
honda400exdude1's Avatar
Default 400ex hotcam question
I have an 06 400ex and i was wondering if i bought a stage 1 hotcam, would i have to buy a big bore kit or would i have to just rejet it? I plan on buying a 426, but for now i want a hotcam. is this a problem?
Old Oct 3, 2010 | 06:58 AM
zooooom's Avatar
The cam will help some without anything else. You don't "need" a bigger bore, but more compression to help the cam is always better. 400ex is like 8.5-9.0 to 1? 10.5-11.0 to 1 will wake it up with a stock bore.
Old Oct 6, 2010 | 06:55 PM
Leroy400ex's Avatar
i had the stage 1 cam in my ex, and the only way to achieve a good gain from this cam is to put a full pipe, and open up the airbox. for that you will need to rejet. a cam swap is un necessary to rejet if thats all you are doing. also if a 426 is in the worksa stage 2 would be the ideal setup for it. also keep in mind that a 426 is the last bore you can go before resleeving the cylinder. i would look into a 416 first with a stage 2 and open air box, with good filter and full pipe. if i didnt get rid of my EX that would be my ideal set up.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
