400ex pulling to the right real bad doing whellies
Old Oct 3, 2010 | 11:25 PM
tiptopss's Avatar
Default 400ex pulling to the right real bad doing whellies
anything I can do about this? It wont stay straight no matter what I try with the air pressure in the tires, have razr tires on there, thanks
Old Oct 4, 2010 | 12:12 AM
Doctorturbo's Avatar
GOT BOOST!
The first thing you need to check is if the axel is square with the frame.
The next thing to check is stagger of the tire. Take a flex tape or a string and measure around the tire to make sure they are the same size. Most likely it's a stagger problem.
You can also swap the tires and rims from one side to the other to see if it is a stagger problem.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
house1
Aug 9, 2015 10:49 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
