2000 Polaris Scrambler 500 charging system?
Old Oct 4, 2010 | 09:12 PM
cjoness75's Avatar
Default 2000 Polaris Scrambler 500 charging system?
Hello everyone,
I have a 2000 Scrambler 500, and it is not charging the battery. The fan also stopped working. Does anyone know if this is a common issue, and what is wrong
Old Oct 5, 2010 | 07:18 AM
TLC's Avatar
TLC
At about 4000 rpm a Volt meter should read about 13.4V. Check that first.
For the fan jump a 12v source to the fan's two wire and see if it still works OK. If it does then your connection to the Thermal switch in the rad to the fan maybe bad or the switch may need changing.
If you ever need a Fan.
Don,t buy a from from a dealer,go directly to SPAL.COM they make the Polaris fans and sell the much cheaper.
Old Oct 5, 2010 | 05:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure the recifier is plugged in and not corroded as well.
bzdok1234
30
Feb 23, 2016 01:55 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
