Need help quick with jetting
Old Oct 4, 2010 | 11:47 PM
Nillious's Avatar
Default Need help quick with jetting
I just ordered a MOOSE jet kit for my 02 500HO. Im a little worried after looking more into it. According to jetsrus the stock main jet is a 152.5
The largest of the five main jets that come in the kit is a DJ155. According to any charts I can find online, the DJ155 is comparable to a Mikuni 145 - 147.5
If these charts are indeed correct, ALL of the jets in the kit are WAAAAY too small for what I need. Ill be adding a IDSX or Big gun Exhause, Moose Foam filter, And will be snorkled. Please tell me I didnt waste 50 bucks
If I can get some info fast enough I may still be able to cancel the order in the morning before it ships out
Old Oct 5, 2010 | 08:17 PM
If the Moose kit is like the Dynajet kit,then the carb slide needle is tapered quite a bit more than stock needle. This in itself will allow more fuel and quicker delivery and smaller jets can be used.They are supposed to be super smart on jet kits,but I think you are paying more for the titanium needles than anything else! Be sure to check plug condition,make sure its not too lean if you use the kit. Just my 2 cents worth ! OPT
Old Oct 5, 2010 | 09:31 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
If the kit comes with a more tapered needle I would suspect you'll be alright. I just re jetted my B-N-laws raptor with a stage-2 dyno jet kit which came with smaller main jets (vs. stock) but a much narrower needle. It had me scratching my head but, He claims it's got gobs more power over stock. He also claims it was hard to pull a wheelie in third gear but now he can do it at will. That tells me the jet kit definitely made an improvement.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Rooky
Sep 9, 2015 03:16 AM
