SP500HO - No drive - Left Front
Old Oct 5, 2010 | 12:25 PM
pwssr's Avatar
Default SP500HO - No drive - Left Front
Lost drive in the left front wheel last weekend. Other three wheels work like crazy, but the left front is an anchor!!
Very well maintained ATV, never an issue previously.
Would appreciate suggestions on what might be the likely cause of this?
Thanks,
Paul
Old Oct 5, 2010 | 12:27 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
year?
Old Oct 5, 2010 | 12:40 PM
pwssr's Avatar
Originally Posted by weedy
year?
Duh - brain lapse, sorry!!! 2001
Old Oct 5, 2010 | 05:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you need to check if there is power goiing to the hub to make sure the armature plate is powered. whens the lst time you changed the hub fluid. sometimes real dirty fluid will make it stop working as well. imo
Old Oct 6, 2010 | 06:02 AM
pwssr's Avatar
Thanks, Sten
This was the second ride on the fluid change. It has been changed regularly and I have never seen it dirty at all.
I'll check the power this weekend. Do I have to have all 4 wheels up, engine running and trans in gear (ie. wheels spinning) to see voltage down there due to the speedometer being in the circuit?
Old Oct 6, 2010 | 08:51 AM
TLC's Avatar
TLC
Here is a good link on working on the locking hubs. ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
You may get luck and its just dirty fliud of a broken wire.
Old Oct 6, 2010 | 10:02 AM
pwssr's Avatar
Thanks for that link - I used to have it and couldn't find it.
I'm hoping it's a wire - fluid was fairly fresh.
Old Nov 9, 2010 | 08:08 AM
pwssr's Avatar
Update:
Took it apart and discovered that when I had it apart previously, the Armature had slipped out of place and wrecked the back of the Roll Cage. Everything cleaned up well, but I need to order a Roll cage and another armature plate. Hopefully, that will fix it.
Old Nov 9, 2010 | 08:24 AM
TLC's Avatar
TLC
Try E bay, my cousin, got the whole strut,spring,hub,rotor and all for $50. It was ta direct bolt on. Worked great.
Old Nov 9, 2010 | 08:38 AM
x2 bum's Avatar
If it is the roller cage you are talking about, I thought I read somewhere that you can buy one for a john deere that is cheaper and better.
