replacing belt on lt80
Old Oct 9, 2010 | 11:20 AM
azlt80's Avatar
Default replacing belt on lt80
My boys drive belt broke on suzuki lt 80 i've removed the case need help from hear to install belt what needs to be remove for belt install any help thanks
Old Oct 9, 2010 | 08:03 PM
kave's Avatar
I haven't replaced as many belts as many on this site but here goes.
I remove the variator fixed face by loosening the 17mm nut on the end of the crankshaft. If you don't use an impact gun, you'll need to hold the crankshaft to loosen/tighten the nut. Holding the crankshaft involves using a special tool bolted up to the magneto with the fan removed (tool attaches using fan bolts). I welded some flat steel together rather than purchase the Suzuki tool. See a service manual for greater details.
Now route the new belt around the clutch while pulling the movable pulley to you. The belt will fall between the pulleys and provide enough slack in the belt to get the variator fixed face back on. Tighten nut to 40ftlbs (I believe).
Old Oct 9, 2010 | 09:34 PM
azlt80's Avatar
thanks boys out testing it out.
toonces
Jul 31, 2015 09:27 AM
toonces
Jul 28, 2015 01:58 PM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
Wnthunting
Jul 9, 2015 03:02 PM
