help atv leaking gas
Old Oct 18, 2010 | 06:18 AM
ratliff71's Avatar
Default help atv leaking gas
2006 honda rancher 400 at pouring gas from mane bottom of carb no tubes just a steel nipple on bottom of carb
Old Oct 18, 2010 | 07:32 AM
budedm's Avatar
Sounds like the gas drain is open. There's a small screw on the side near that nipple. Make sure it is screwed in. There should be a tube attached to that nipple that runs downward and doesn't attach to anything at the bottom. The screw drains the carb of bad gas. You're supposed to put a can or something under the end of the tube.
Old Oct 19, 2010 | 08:17 AM
Koopa's Avatar
Is addicted to 4 wheel'n!
Could be the float is stuck. Tap it with a screwdriver end to see if it stops. If it does prob time for a carb cleaning.
Old Oct 19, 2010 | 04:07 PM
sdm111's Avatar
2 strokes or 4
Yeah, what he said. And if that dosen't stop it you probably have trash in the needle valve.
Old Oct 19, 2010 | 10:32 PM
JeffinTD's Avatar
Yeah, that's the float bowl overflow. Likely the seat and needle have gunk in them.
Also make sure the gas tank vent is not obstructed.
Another possible cause is the diaphragm of the primer **** (I think it is so equipped). If there are cracks there, fuel will flow into the intake and float bowl and overflow the carb.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
