Help with old start Honda Fourtrax 250
Old Oct 19, 2010 | 02:33 PM
HondaRevival's Avatar
Default Help with old start Honda Fourtrax 250
After spending about and hour or two just trying to kick start it, my old Honda Fourtrax 250 fired up. It runs, but I know the carb needs to be cleaned. There are some other things that worry me though.
When I reverse it out of my shed (at an incline of about 30 degrees) it sometimes dies and makes a weird sound, kind of like a clanking sound. I usually just roll it out in neutral and then go.
Also when I go up a small incline it'll lose some power but that's probably a side effect of the dirty carb.
The last thing I noticed is that when I get into 3rd gear and up it just doesn't feel right. I don't know how to explain it, but it seems unsettled.
Any help would be appreciated.
Old Oct 19, 2010 | 02:49 PM
budedm's Avatar
Check all bearings and bushings.
Old Oct 19, 2010 | 02:51 PM
Will do, thanks.
Old Oct 20, 2010 | 03:30 AM
aaronrkelly's Avatar
I would get it running good and healthy first....the unsettled feeling, the noise etc could all be from a poor running engine.
For instance if the engine is misfiring it could make the whole ATV feel "unsettled" - surging, shaking etc.
Old Oct 21, 2010 | 03:03 PM
The definitely could be the case. Whenever I take the choke off I have to play with the throttle to keep it running. Too much and it dies and too little it dies, So I gotta play with it and it doesn't keep running when I let go unless I put the choke back on.
Old Oct 21, 2010 | 03:10 PM
Also, I definitely get surging too. It'll just start to die and then kick back in, or it'll just be jumpy.
Wooodyii2
Nov 16, 2020 07:14 PM
1000gade
May 27, 2015 12:37 PM
PuhiStrain
Sep 9, 2000 01:36 PM
blazer316
Sep 8, 2000 10:53 AM
lovinhonda
Jan 25, 2000 09:17 PM
